dana 44 replace d35 yj
v7nf
has any one welded the new perches on a dana 44 when swaping them on a yj?did you weld them directly under the top perches?same location?
you can if you are retaining a spring under configuration, spring over they would be opposite.
They will not be in the same position as the location of the leaf springs and pinion angles vary a lot between vehicles.
