Joopin
Super Moderator
Hey folks, It's been a while!!
So, I don't have an XJ, but I do have an XJ D44 rear axle under my YJ... which is leaking from the drivers side outer seal. Yesterday I took off the tire and drum just to check, and there is all sorts of crud in there. So my question since I have never done this before...
What do I have to do to replace this seal? I know I have to pull the axle shaft, but I'm not sure how it is held in there... c-clip? pin in the diff? retaining ring? I should say that the axle is out of a 1988 XJ with the towing package... it has 4.56 gears with a limited slip.
I've looked around online, can't really find anything on this specific axle... and since there are a bunch of different D44s out there, I would like to be prepared for this one.
Any input would be great. Thanks!
