Allen's Offroad
Currie 9800H 4" TJ or 9800HL 4" LJ Suspension and Bilstein 5100 Shocks for $2119.95
The Currie Johnny Joint® suspension system kit is a complete package that replaces all eight stock control arms and provides a 4" lift. It is engineered to provide unrivaled articulating flexibility and performance in the most adverse off-road conditions. The Johnny Joint® system keeps the tires in contact with the terrain for maximum traction. Kit includes 8 Johnny Joint® control arms, 4 4" lift coil springs, Johnny Joint® adjustable front trac bar, rear trac bar relocation bracket, front sway bar disconnects, rear sway bar extended links, and the Currie front and rear poly urethane bump stop kits. When used in conjunction with a 1" body lift and a 1" motor mount lift, this kit allows for efficient use of up to 35" tires.
Many other Currie products available. Have a blessed and properous day!
Namaste,
Allen
You got it! Currie Enterprises 4" TJ/LJ suspension and Bilstein 5100 shocks for $2119.95 shipped in the lower 48 US.
Californians add $151.13 for tax.
Namaste,
Allen
