hey everyone, hoping you folks can help with this
1, how can i remove my nj inspection sticker, to install it on a new windshield?
This can be done but it is illegal (atleast in Pa) If you take a propane torch and heat the outside of glass (don't hold in one spot) then gently use a raxor blade to scrap up a corner so you grab ahold of it, then keep heating it and working it off from the glass. This will ruin the glue on the sticker and you will probably need some super glue to adhere to the new windshield (only in a couple of small spots).
But, if it were me I would take it back to the inspection station and have them do it. most of the time they will only charge you for the new sticker and not the whole inspection process.
