1061400
Specs: 91 YJ 4.0 5sp 35K; Problem: If I push the clutch pedal and shift fairly quickly I have no problems, but if I push the clutch pedal in and give it some time I have to "double clutch" to get in gear or out of gear. Doesn't matter what gear I'm in or if I'm in neutral, if you hold the clutch very long I have to "double clutch". Clutch fluid level is fine. Any ideas?[addsig]
