hoobness
My steering is terrible and just plain unsafe. While taking the box out the other day I realized why. The shaft (sector shaft?) attached to the pitman wobbles, the coupler at the box is shot. The upper joint that meets the column under the master cylinder gives the wheel 10 degrees of play alone. ..you got it, its just plain silly to attempt any normal driving, not dare take it of road lol. So I'm looking at a new shaft, try to find a borgeson knock off with u joints. And a steering box, prob needs ball joints, tie rod ends, but that's another thread.
I want variable rate steering. J20, early camaros, H1 etc are options, does anyone know of other options? So far the cheapest is the camaro..plus being newer prob has less wear..no?
Anyway, I don't want another cj box. Expensive and no variable rate steering.
Thanks again!
Thanks again!
