Cherokee XJ - Hard shift auto when cold?
Mike1
Hi All
I have a 98 XJ, recently it has started to shift hard up through the gears on initial start up when cold. Once the vehicle heats up then the shifting becomes normal again. I have checked the transmission oil and it is at the correct level with engine running in park, the oil is the correct spec. as per the user manual, and the service on the transmission was done around 4000 miles back? I only use the vehicle once a week on weekends, so it stands most of the time, what other obvious faults could there be, possibly a pump of some sorts needs to be replaced or should I do an oil change and service again, possibly something is blocked?
Regards
Mike
Hi All
Regards
Mike
did you replace the filter in the auto box?
Filter was replaced with service approx 4000 miles back, and box never shifted hard when cold until around 3 weeks back, there arent any leaks and oil is clean, also havent done any river crossings so no water in oil?
Mike
Hard shifts beat slipping any day. Have you done any top end work on the motor lately? TB or intake. Is it possible your TV cable is out of adjustment?
If the TPS is acting up and it shifts late it will sometimes shift harder than normal.
It only does it when cold, once warm shifting is fine again, no work done on Jeep lately, only item I can think of was a trail we did around 3 weeks back, it was a moderate trail but didnt hit her on anything and didnt do any water work?
Mike
I am having the same problem in my xj 95, I changed the transmission oil, transmission filter but with no good results.
Someone told me that there are special set of sensors which gets week and should be changed, others said I should reset the computer!!!
anyway I changed the type of fuel and began to use "octane 95" since 5 days and I think that this problem disappeared, I wish it will not reappear again.
Hi ,
I had the same problem returned again, I searched the net so I found this site
http://www.autozone.com/az/cds/en_us/0900823d/80/15/40/6a/0900823d8015406a/repairInfoPages.htm
please read the article about TV cable adjustment as "MudderChuck" adviced in his reply, I did it myself and I was astonished to find my cherokee got completely changed and the transmission is no more hard to shift.
I wish it could help and thanks for "MudderChuck" for her valuable advice.
Throttle Cable
AW-4 AND 30RH/32RH MODELS
See Figure 6
Have a look at the pic for "Throttle Cable Adjustment" . here......
Jeep Cherokee Transmissions - AW4 Automatic - AW4 Throttle Cable Replacement
