hey there, i have a new 1994 I6 4.0 cherokee that i recently bought. i just ordered out and mounted new 35" BFG KM2's on her. i went wheeling pretty hard as soon as i got the tires on. i now have a ticking noise that seems to be only when i am moving. it sounds similar to what my locker sounds like when i turn. perfect description would be that it sounds like a ratchet. it gets faster depending on my speed. once i get going fast enough i can no longer hear it though. also developed is a whacky oil pressure. as soon as i got the tires on i noticed that the oil pressure was basically never below 60. and certainly not below 50. right at start up it will idle at 40 but as soon as i get going it goes to 60ish. i figured this was semi normal because of my larger tires and the increased work load. i did notice that at higher speeds the oil gauge seems to fluctuate (before offroading). i drove the freeway yesterday (after i went wheelin) and noticed that the oil pressure was at or past 80. i was going a normal maintained speed but the gauge was "jumping" up and down kinda going crazy. it would go as low as 70 and then it would jump back up past 80. it would then sometimes even out and maintain at 50-60. my rpms are not crazy either. does anybody have any ideas on what it could be!!?? if you do try to include how to fix the issue if you can. and also if you can please try not to abbreviate anything without saying the full word as well. i'm newer and still trying to learn everything. thank you all!
