Have a 1990 4.0L Cherokee automatic transmission that is backfiring on acceleration or load (going up a hill). Runs great down hill (of course) and idles good. In order to go up hill I have to floor the accelerator and kick it down in low gear. It seems to work fine if I floor the accelerator peddle but hesitates if I accelerate gradually.
Things I have done:
Checked injectors (they were replaced about 30,000 miles ago.)
New rotor and cap
New fuel filter
Cleaned the O2 sensor (did not replace so it could still be bad)
Cleaned and regapped the plugs (all showed white deposits at gap)
Cleaned and checked all vacuum lines from manifold to various sensors and all seem to be OK.
New air filter but I am still getting some blow back into the filter from the PCV line into the filter element.
Disassembled the throttle body and cleaned it.
Has anyone had any experience in the symptoms of a plugged catalytic converter on a JEEP? Could this be the problem?
What sensors should I check that could cause this problem?
Is there a relation to acceleration and the automatic transmission? I seem recall seeing some information regarding a sensor or switch that is supposed to adjust throttle as the automatic transmission shifts.
Thanks for any input or suggestions
Things I have done:
New rotor and cap
New fuel filter
