About two months ago I had my top down and it poured (wonderful Miami weather). Needless to say my TJ was flooded pretty bad. After this rain, I began to have problems... check engine light came on also the airbag light. Cruise control wasn't working. I started having problems while driving. I would lose power and then suddenly get a too much. I noticed that my mpg were not the best either. Eventually my cruise control started working. Every once in a while airbag lights goes on and off. I went to check out the CEL...and got Po123 code... I changed the TPS and still have the same code. They checked out the voltage and mentioned that I might have to change the computer.. before I spend all the money on a new computer is there anything else I can check... I'm doing about 150 - 160mpg... RPM go past 1000 when idling... and i lose power when I drive.. I'm also getting P1596 code....i was doing some reading and some people mentioned the clockspring? any thoughts to my problem!
Thanks!
Thanks!
