A few years ago I purchased a 2bbl carb from Autozone for my project CJ. It's been sitting in a sealed box until now. The motor is finally reinstalled, but I have fuel running out of a fitting on the carburetor. There are two fittings (ports?) on top of each other, and the top one appears to be bronze (at least in color) inserted in a plastic triangular shape. The bottom is stainless. No hose connects the two. I found a pic online that I believe is connecting the two fittings, but the are on different sides than mine. It's a re-man Champion model number 9-224 for a 1982 CJ. Should a hose connect those 2 fittings?
