1069797
I have a 95 YJ. 2.5 manual
The front output from transfer case is to the driver's side. Since the 6 transmission to transfer case bolts are equi-distance, is it possible to rotate the transfer case 180 degrees so the front output is on the passenger's side?
I am doing this to accommodate passenger side differential.
Probably have to drill new drain plug and vent holes and relocate the exhaust.
Will I screw up the T-case lubrication system since it will be operating upside down for the rest of its life?[addsig]
