Can I Permanently Remove Stepper Motor?
pmarkmcg
(I'm cross-posting this in other forums)
When doing a Nutter Bypass, if my existing Carter BBD has a stepper motor, is it possible to fully remove the stepper motor and plug up the area where it was attached?
How would you do it?
Are additional modifications necessary?
Is there anything special to tuning the carb is the Stepper meeting pins no longer exist?
I haven’t done this myself but read you just unplug the motor. You pull out and set both screws / way. Then set your fuel O ratio with the pins.
