Can I Permanently Remove Stepper Motor?
pmarkmcg
(I'm cross-posting this in other forums)
When doing a Nutter Bypass, if my existing Carter BBD has a stepper motor, is it possible to fully remove the stepper motor and plug up the area where it was attached?
How would you do it?
Are additional modifications necessary?
Is there anything special to tuning the carb is the Stepper meeting pins no longer exist?
I thought you had to set the stepper motor to a certain spot qhen doing the nutter bypass?
My earlier post is deleted??? I have not done this myself but understand you could leave the motor in and unplugged. Move the two motor valves by hand so they are equal snd about 1/2 way. Then adjust your air /fuel with the pins.
