broken axel shaft
kevin4x4
broke my axel shaft today. Got IT home put it on the lift pull the shaft out .drain the fluid. What to do next never replace on before. Its a dana35 locked. need to know how to instal and if they make something stronger than stock..... thanks for any info
there is a Super D35 axle kit.... just basically stronger shafts
new axles
The Superior kit upgrades the spline count from 27 to 30, so the whole kit is needed not just the shafts. The kit includes a new Detroit locker to match the bigger shafts. Because of the better materials and manufacturing process, with the kit you will be stronger than a factory D44 as far as the shafts go, but your housing is kind of weak. A full length heavy truss should be considered.
http://www.footeaxle.com/Pages/start.html
If the link doesn't take you straight to it, click on the "Evolution series...." on the left side of the screen.
new axles
och kinda expensive.. any other.. Can U get just a axel.. What some different name brand of axel.... thanks for the info so far please keep it coming.. :lol:
