been a while
suthrn98
hey guys I haven't been here in a while. But on my 94 ZJ i have installed the 2 inch BB. What is the biggest tires I can run? I have heard 31s, but what size rim can I do. I am gonna order some cragars from www.quadratec.com I think they are the 398's. Which size should i go with? x7 or x8?
zj exhaust
also these wheels have like 4 inches of backspacing i think it said. would these wheels be ok to run some 31x10.50s?
<IMG SRC=http://www.quadratec.com/photos/p31136.JPG>
RE: New to the Jeep World, Have some Questions
You should be fine with 31's and 2" BB. I run 30x9.5's stock on my 94 ZJ with stock rims with only minor rubbing at full flex and turning. 32's would probably be a little tight on the wheel well. It really depends on how you wheel it and how much rubbing you can live with.
Re: CJ doesn't run right...engine surges
i run 31's on a 2" bb and had to trim to fit a little bit, so thats what i would recommend. anything bigger and you're on your own. and if you're going to buy new wheels, go with the 15x8's, if you were going to buy the 15x7's you could keep your stock ones. just MHO, cause you know you're just going to want to go bigger once that is installed anyways.
