You will need a transfer case drop to lower the belly skid 1", or install a SYE and CV rear driveshaft. The transfer case drop isn't too bad, you're only losing 1" under the belly in clearance after gaining about 5" from the lift and tires combined, so you're still 4" improved belly clearance from stock.
