I rebuilt a 2.5 recently and just got it buttoned up in my 94 YJ, tried to start it for the first time Saturday and it turns over but won't run, I suspected an ignition issue so I've been poking around and think it might be a bad coil. I checked the primary and secondary and the values are correct however when I install it and ground against the block I see no spark at all... the cap, wires, rotor and plugs are new. I plugged my multi-tester into the coil plug and have 12 volts with the key on so there's the question is it as simple as a new coil or are there other checks I should do, what triggers the coil sending the high voltage just the act of turning the key? Can anyone shed any light on my questions? Thank you.
