I knew when I started this swap that it wasn't goin to be easy, but wow, is it turning into a serious pain in the behind. I have a '93 wrangler with the 4.0 and automatic. I decided I wanted to put a 5 speed in. I found an ax-15 that was supposed to be from a '94(I wanted the external slave). Unfortunately when I went to pick it up, it had the internal slave. Still couldn't pass up the deal, so I got it. I then got a bellhousing from a 95 xj. Unfortunately the sensor on my yj does not fit the xj housing. I bought the xj sensor, hooked it up and gave it a try. The jeep tries to start, but after a few seconds it just sputters and dies. I unhooked the sensor and tried it, and it doesn't even sputter, so I'm pretty sure that's the problem. My question is, can I find a bellhousing that my original sensor will fit, or do I have to get a different computer? I'm also having other wiring issues, but for right now I want to get it started.
