cjmistress
Does anyone have the actual numbers for the AMC 20 wide trac and narrow trac axles. Are they measured from hub to hub, brake plate to plate? I need to order solid axles and not sure which is under there. 81-82' cj7. I can't read the numbers on the axle, I'm at work![addsig]
