Baseline 4x4
The Alloy USA® Differential Cable Lock Kit is a permanent replacement for the failure prone OE vacuum disconnect system. The kit allows you to engage and lock the front axle from inside the cab. A 1” pull of the cable ensures you will have four wheel drive when you need it for as long as the transfer case is engaged. The Differential Cable Lock Kit is more cost effective and easier to install than a locker or posi-trac system. Backed by a three year warranty.
450920 - Alloy USA Differential Cable Lock Kit, For 3-In To 6-In Lift, with Front D30 Axle, Jeep Wrangler YJ 1987-1995, Cherokee XJ 1984-1991
450900 - Alloy USA Differential Cable Lock Kit, with Front D30 Axle, Jeep Wrangler YJ 1987-1995, Cherokee XJ 1984-1991
450100 - Alloy USA Shift Fork, Cast Iron, For Use W/ Alloy USA or Posi Lok Differential Cable Lock Kit, Jeep W/ Front Dana 30 Wrangler YJ 87-95, Cherokee XJ 84-91
The 4x4 Posi-Lok System™ will fit the following applications:
1987 to 1995 Jeep® YJ Wrangler the Dana 30 vacuum actuated front axle
1987 to 1991 Jeep® XJ Cherokee the Dana 30 vacuum actuated front axle
The 4x4 Posi-Lok System™ is a permanent replacement for both the original equipment vacuum and electric axle engagement systems
The installation of this kit gives you direct control, of your 4 wheel drive system, from inside the cab
A one inch pull of the cable ensures you will have four wheel drive when you need it
Simple and easy installation
Note: This system is not a posi track or locker system
PSL920 - 4x4 Posi-Lok Vacuum Actuator Eliminator Kit, 3" To 6" Of Lift
PSL900 - 4x4 Posi-Lok Vacuum Actuator Eliminator Kit
PSL100 - 4x4 Posi-Lok Dana 30 Front Axle With Disconnect, Cast Iron Shift Fork
