air intake and vac lines
donnie850
my factory air box is warped, wont fit a filter anymore, i just ripped it out. Now i have vac lines hanging and no filter lol. It runs like crap at idle till warm. Has some power loss. I want to use PVC to make a new intake with a cone filter. How and where do i run the lines that were on the original air box?
You can buy brass fittings at home depot type stores. Drill a hole in the pvc just big enough to start screwing in the fitting, practice on a scrap piece, the brass will cut its own threads in the pvc pipe.
Yep that'll work perfect man, it's the same thing i did, all a vac line needs is something to get a little pull off of, if it doesn't get that pull it'll make it run really bad and decrease your mpg as well. Hookup those lines like tnt said and you should be good to go.
any chance i could a few pics of yours?
Where in FL are you? panama city here
