Air Conditioning
MudderChuck
Don´t use it often, but Grandma appreciates it, when I take her, on her weekly shopping trip.
Question is, I don´t really know if the system has been changed to 134a or is still F-12. There is no apparent conversion tag. What is the easiest way, to tell if the conversion has been done?
The AC seesm to be functional, but doesn´t perform as good as it might. I´m thinking it´s probably a little low on freon. I´ve still got some R-12 stored in the garage.
88 XJ limited, with all the creature comforts. Real comfortable off roader.
edited by: MudderChuck, Jul 12, 2003 - 08:23 PM[addsig]
1075888
look at the pressure connections on the high and low pressure lines. if the system has been converted to r-134, the connections will have quick-disconnect fittings screwed onto the original valve stems. if the system is still r-12, the connections should look like tire valve stems.[addsig]
