Advance Adapters 716073E,VSS kit for GM 4L60e
Bounty__Hunter
Super Moderator
Note: This kit only fits 4L60E with 1 piece case, 4 bolt rear case with a stock GM output shaft. If the 4L60E is using one of our Advance Adapters output shaft, refer to kit 716073
This VSS kit will provide a 1-to-1 reading on the1993-96 4L60E out put shaft even if the transfer case is inlow range. Kit includes a VSS sensor, clamp on tone ring, installation hardware, and adapter instructions.
Can be used on newer 4L60e transmissions with instructions found online. This kit is new, never used, my loss is your gain. Includes an extra used speed sensor. I had planned on using this to install a GM drivetrain into my Jeep Comanche, also good for Cherokee and Wrangler.
No trades, firm on price. $200, Waterloo IL.
