PhattyX
The newly aquired TJ has a 2" suspension lift and 33" tires. On the road, it's fantastic. No rub at turns; No scrapes on bumps. Off road, however, the tires rub horribly on the fender flares... and what appears to be the fender itself. Mostly the front. Is this typical of 33's under a 2" lift.
Looking at options, what's the best solution and what's the cheapest? I know a body lift will probably be cheapest and do the trick, but I'm not sure I really want to go that route. Would flat fender flairs (Bushwacker or Metalcloak type) be enough? Would it make sense to go ahead to a 4" susension lift? Since I just bought this, I'm not excited about throwing a bunch of cash into it.
Are there other options that I'm not thinking about?
Thanks for any input or suggestions/opinions,
-X
-X
