98 TJ timing issues
Tfields
So I'm trying to switch out my timing gears & chain out on my Jeep. Finally found out that the previous owner upgraded them & they're Crown Automotive parts. I've ordered a set that matches the part number on the cam shaft gear & it arrived yesterday & the cam shaft hole is to big & it has a "raised lip" around the shaft hole where mine does not. How can I figure out if the cam was switched out?
Sent from my SM-G930V using Jeepz.com mobile app
