2.5L. It ran fine before I left on vacation. Upon return, engine cranks but won't catch. We have had monsoon rains and 100 % humidity, so I inspected inside of cap and rotor, no problem. Got variances on the coil so replaced it, still no spark. I sprayed ether into the intake and it didn't fire, so I'm reasonably certain it is a spark problem. I pulled and re-seated the relays and inspected the big fuses. I checked tight clean connections on TPS, CPS and MAP sensor. There is no Check Engine lit, either. What next? It's not the crank position sensor, which was a crowd favorite in other forums. Changed it out and it still won't start... Help me, Mr. Wizard!!
