96 Grand Cherokee ABS problem
rspicer
Please help if u can,,
my 96 grand cherokee's brake pedal has started pulsating at 10 mph and less
when stopping. Kinda like ABS effect on a slpippery road. I couldn't find a problem w/ the sensors. I have since unplugged the ABS module at the master cyl. Braking is fine now with the exception of no ABS and the ABS light staying on all the time due to the module being unplugged. Any help would be greatly apprecaiated.
Try this: Take your vehicle to AutoZone or your favorite auto repair shop, plug in the ABS module at the master cylinder, and have a diagnostics check done on the vehicle (trouble code analyzer). That may lead you in the right direction as to the true problem with your ABS unit. As for your current braking status, just remember that you don't have ABS ;) Hope that helps.
By the way, welcome to Jeepz.com!
