94 yj brake problems
kelamb
do the 94 jeeps have abs brakes. I am asking for a friend of mine...she said she has had some problems with her breaks..not feel like they are catching when she is going down a hill...can someone please advise what they think it might be.
I have heard of Warped brake rotors causing this on TJ's. Usually can be fixed by getting them turned.
Yes, the '94 was available with ABS. Sounds like your friend needs new brakes, doesn't sound like something that can be pinpointed to one problem.
Is sky Jacker a good lift.
I have a 93 wrangler that has problems with the calipers freezing up all the time.
It was always an option.
Look behind the knuckles on the front axle where the axle ujoint is. You will see the tone rings attached near the ujoint if it has ABS.
