6cyl / 4.0
Manual
Installing New Clutch Kit
Ok. Finally got everything off, resurfaced the flywheel, installed clutch kit, got all back together BUT now it won't shift with the engine running. The clutch pedal is firm and has consistent pressure. Is it possible that I haven't bled the line enough? I didn't think so based on the pedal pressure. I know the kit was not installed backwards as I triple checked immediately after aligning the clutch. It shifts perfectly when the engine is not running. Help!
Manual
