Purple Frog
My grandson just had to have a Jeep.
His parent bought him a 91 with the 4 banger. So I have spent a LOT of time doing repairs.
The fuel guage quit working. Cut the tailpipe, dropped the tank, and installed a new fuel pump/sender unit assembly.
Now, turn on ignition the guage reads fine. Start driving, guage reads fine. Hit it brake pedal, guage drops to zero.
Only one other issue with vehicle currently. I'm only mentioning it because of any possible relationship.
The brake warning light on the steering column stays lit no matter what. All four corners have new brakes, new master cylinder (full), bled properly.
Anyone got any idea where to proceed?
I'm worried that the symptom could be causing the sending unit to burn up. So, i don't want to keep hitting the brake.
ECU starting to fail?
Thanks in advance.
Thanks in advance.
