jeebusroxorz
Hey there all. I am buyin a 91 Cherokee (6 cyl, MPI) but first I get to fix it!
Heres the low down. I fixed a few small things, including an oil leak. It had it for a while and built up a nice coat of dirt, grime sand and oil all over. I degreased it and guess what! A problem...never fails. Anyway, I cleaned it on Sunday, let it sit and dry until Monday. Started right up. Wed I went out. Started it, put it in reverse it dies. Now its not starting. Itll start to go, run for a second and die. Sometimes it will start, rev REAL high, the belt will squeal (like a piggie) annnnnd then die out. The few times it will start I give it some gas and it stalls out. I used to get error codes 14 and 13 (Bad voltage to the MAP and bad vacuum lines). Those have gone away but Im still wary of the lines.
So now Im pulling at straws. Im hoping someone could give me a hand. Ive got a few ideas of what it could be but Id like some more input. This is the first jeep Ive worked on.
Thanks Alot
Thanks Alot
