scubasteve
Hello,
I bought my first jeep today as a starter (to get around this winter and off road next summer). all i could afford for a toy for now... I am pretty mechannically inclined, (spart, plus fuel +air= go) etc, but I am not sure where to start with this project.
So with that said, it is a 90 "grand" cherokee laredo with a inline 6- 4.0 and if starts after a few seconds of cranking and runs pretty smooth at idle.
now for the bad. It will not accept the gas pedal being pushed. It starts rev up, but starts to backfire and pop and will not rev up at all. (let off the gas and it runs smoth at idle again... I think the engine has been replaced as the odo says 181k and the plugs are brand new and the guy I bought it off of said it was, but couldn't figure out the problem... so, in order to start my daig process, I thoguht I would ask any experts on here.
1. I herd that 89-90 have a different ignition/ fuel system that is more dificult to work on - any truth to this?
2. Does anyone know of an id tag/casting to tell the year of a block/ engine to verify engine is correct for the different system if applicable?
3. Where shoud I start checking other that fuel pressure/ air supply (lack there of -ie clogged cat/ filter) it apperas that the plugs are new, and the resister has been changed. It has a brand new radiator and had clean oil (ie doesn't appear off the bat to be head gasket...
I have read a bit on here already to see of similar problems and none seem to match my exact problem.
thanks
steve
thanks
steve
