Adioman008
I am finishing up my 4.0 swap and I have to jump the starter to get the jeep to start. I have checked all the fuses and relays and nothing. Tonight I ran a wire straight from the starter and plugged it into the slot on the ignition switch with the wire that is suppose to go to the starter I turned the key and it fired up and ran. My question is will this damage my system. I also installed a push button start can I get ride of the push button start and just run the wire to the ignition switch on the steering column.
I have an 89 yj that had the 4.2 but now it has the 4.0 I swapped all the wiring in the entire vehicle and swapped gauge clusters and speedometer and tach. Any input would be greatly appreciated.
