I have an 89 YJ, randomly the headlights, tail lights, brake lights, dash lights, and hazard lights all stopped working??? The reverse lights still work and the signals work. I have been searching for the problem with no luck. Checked the headlight switch, dimmer switch any relays I can find. I have tried following the Chilton wiring diagrams but not the easiest to follow. I have a feeling I am overlooking something simple?? I have voltage to the main switch as soon as i turn it on all voltage is gone, the same thing happens if I put a jumper wire in and bypass the switch. Any suggestions would be great!
