86' jeep cherokee not engaging into gear..(new clutch) HELP!
pinned
Hello,
I purchased a new clutch, throw out baring, everything.. installed it.
Im getting good presure on the peddle after bleeding it. checked all lines everything seems good to go(but the truck)
..I start it up.. try and put it in gear(manual transmission) it will not go into gear.. Im curious if anyone knows what could be wrong or i didnt do properly. thanks![addsig]
1054133
More info please. Is the shifter going into position but the gear is not engaged, or is the shifter not moving at all, or is the shifter moving and the gears engaging, but the truck not moving when you let out the clutch?[addsig]
