‘85 CJ 350 swap help
Cutter719
Hello !!! New cj owner and new to forum. My cj had a 350 swap and now has shift box on floor. A B&M race shifter was put in and the box impedes 4WD shifting. Can I just replace shift bar or do I need to replace entire unit ? Lokar shifters ? Thank you in advance !!!! Sincerely- Cutter
A picture of the situation is worth a thousand words.
If we could see it, we could suggest a fix.
I know this was posted a while back but if you happen to see it and haven't fixed the issue yet, we might be able to offer insight if we could see the interference you are having with the 4WD lever. Chances are, you may be able to bend it a little and fix the problem but without a pic, it's hard to tell.
RR
