Tug-n-pull
Hey,jeepz.com is the 422,500
When to the woods in my CJ7 with power and disc breaks on front. After a rough section of trail I went for the breaks and the pedal went to the floor. Master Cyl. was very low on fluid. I was able to pump em up and they worked but went soft right away. I feeled up the master and it seemed ok not leaking down. I bleed the breaks all away around and the pedal felt good, let it set a few mins and down they went again. Now if you are rolling slow and apply the breaks you get a growl every half turn in the driver side front hub area. Just have not had the time ot get in there but think it may be a front calaper gone bad. Any ideas. tug
