'74 DJ5 on CJ chassis $500 obo Seattle
should there be a delete function for old ads?
  • yes
    Votes: 0 0.0%
  • no
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
carnuck
Has on board air
Steering is on the normal driver's side, but an ex-Postal Jeep 2wd. My son started building it (has the centered D44 still in it along with some leaf springs from an old Cherokee and a pair of XJ axles to go with)
Not in driving condition due to the trans change but registration is current.
Motor: 232 AMC 6 runs but burns oil. Swapped to Carter 2 bbl intake and '80 exhaust manifold. (carb is buried in my garage since the move)
Trans: 998 auto aka 32RH (was Borg Warner auto)
Tcase: NP208J (stronger than a 231 and already fixed yoke)
Axle: D44 rear on too long springs and 2wd front.
Comes with 2 XJ axles (D30 and D35) 3.73 ratio (from an '86 XJ 4 cyl)
May have driveshafts too.
Steering box is an old power one from a full size Jeep (it had a bad leak but worked fine as a manual since the DJ5 is light) The motor is set up for PS.
I have a running 258 that can go with this Jeep once I pull it
Note that I have a bunch of other Jeep stuff for sale so a package deal may be arrangeable.
Also have a running 360/T18A/NP208 and J20 axles (D60 rear and D44 front)
Sold! Can't find a delete button or edit button?
