bucarooone
Looking for technical info: My project is to build a "Towed 4X4" to flat tow behind my motor home. The vehicle will be a 1981 AMC EAGLE. NOW FORGET THAT I TOLD YOU THAT!!! All my needs evolve around selecting the right "NEW PROCESS 2 SPEED TRANSFER CASE" that will allow the vehicle to be "flat towed" w/driveshafts in. I have both systems for a "front axle disconnect and full time (non disconnect)". I had hoped to use a NP 229 for full time dry pavement use, but don't believe this possible. I have all the technical input necessary to change from single speed to a two speed T.C. I must utilize a New Process Case with 23 spline to simplify the installation on the EAGLE. Hope someone out there knows how to select and/or modify a N.P. unit that will tow in "absolute neutral" with driveshafts left installed. This would negate any and all transmission concerns, and heat or friction wear to the transfer case. THANKS TO ALL!
FRANK/PHOENIX[addsig]
