4.0 overheatin i need help
92__cherokee
i gotta 96 grand cherokee 4.0 and im havin problems it keeps wantin too run hot if you start it and not drive it itll hit 210 and never gett any hotter and the thermostat dont feel like it ever opens but you can go drive it and itll run the 2nd and 3rd mark past 210 mark iv putt 2 water pump in it and 3 thermostats and flushed the system twice and still cant figure it out
I too own a '92 cherokee (but this post is of your '96)and water pumps either last a while or just suddenly start dripping. Thermostat change is 1-2 years on my jeep and that usually works . Question : are your back flushing the heater core ? When you flush the system , are you squeezing the lower radiator hose when filling radiator with coolant and water ? You must get the air pockets out . This WILL cause temperature rise RAPIDLY . For now. With engine cool , take radiator cap off and squeeze lower hose and watch for escaping air bubbles. You must squeeze in such a way that you are trying to push liquid in and through the engine to circulate the liquid back toward radiator for air to escape . This will take some time and your right hand will get quite a workout . But you must be sure to get all the air out . Keep the radiator topped off so that liquid volume will force its way into system and through to push liquid back toward radiator to push air out . As long as your system is air pocket free and circulation is good throughout ( radiator , heater core , hoses , etc.) and hot water valve for heater core is operational you can have a better idea of the engines condition. Are you losing coolant ? Any leaks ? Pressure loss at cap ? You want to be sure no pressure is lost and a good idea is to test radiator with pressure tester pump . If radiator cap is old , replace it , don't even bother testing it with pressure tester adapter if so . Only test a new or fairly new cap .
Lastly , I certainly hope the head gasket is not bad as if the coolant pressure is lost at cylinder head and is leaking past head and block or into cylinders and oil ports , you know what that means. Head gasket and cylinder head inspection for cracks . I don't want that for either of us. I have to add every so often and I still have to bleed air from my system from the last flush as my electric fan goes on when gauge is getting to 210 or over too . But prior to my last flush , was running cool . Please try getting air out and hope for the best . If this is recent , it may just be air . But must be done ASAP to avoid engine damage !
Sorry , forgot to mention , what condition is the clutch fan in ? If it is slipping and worn , it will not be spinning at fast enough speed above idle to cool radiator properly . How is the electric fan ? Is it turning on when engine approaches 210 or so ? Is electric fan operating with a/c on ? Please inspect all advised soonest , need to avoid a dangerous running condition for your engine !
