350 TJ swap
jeepin916
Active member
does any one know how i can hook up my gauges to the new 350? i thought about cutting and splicing wires but i dont know what wire goes where..???
wiring is the toughest job of a swap.... it is best to find what wire went to what gauge from the 350, then run them to the same gauges on the jeep.... much will be trial and error, and a manual will be much help
no i didnt tag the wires but a buddy of mine works for chevy and knows what everything is for i know some of it but not all so he can tell me. but if i run the wires from teh chevy harness to the jeep cluster do i still have to splice the wires together? or can i buy an adapter harness???
You'd better do a little homework on hooking that stuff back up. You may have the right gauge going to the right sender, but the senders may have different resistance values and such. You'd probably be better off to adapt the senders from your 4.0 to the 350 instead of messing with the wiring.
Just my thoughts
well i was thinkin about it.. i can do electrical work but i hate it....
i could hook up the original gauges to the engine so the computer thinks everything is working fine but i can hide that under the dash and in place of my cluster i can punch holes in them and put mechanical ones in place of the electrical ones. u think that might cause any problems????
jeepin916,
Firemanharry gave you the straight skinny: in addition to the wiring paths, you must also contend with sending unit to dash gauge compatibility issues. The SB 350 into Jeep swap is so common that somebody will surely come along to give you the required info for gauge hookup in a TJ.
In the meantime, what follows might or might not be applicable to your situation, but for what it is worth: before the present "Bubbacon Edition" 85, CJ-7 entered in my life, there was a "Testosteroneacon Edition." An 82, CJ-7 with Chevy 350, HD-four speed, manhole cover sized Holly carb, headers -- all the usual stuff.
Here is how I met the dash gauge wiring challenge:
Voltage Gauge: No wiring modification required. Worked just by virtue of hooking up the starting-charging-ignition systems.
Oil Pressure Gauge: under dash mechanical aftermarket gauge.
Temperature Gauge: under dash mechanical aftermarket gauge. Engine end screwed into the 350 block below exhaust manifold between the 1 and 3 cylinders via a hardware store common plumbing fitting.
Gas Gauge: underdash mechanical gauge selected on the basis of the stock gas tank sending unit resistance values.
(Note: The OEM gas and temp gauges were fried before the engine swap. It was less expensive to go with aftermarket replacements.)
I realize that you would likely prefer to use your OEM in-dash gauges and none of the above deals with possible computer issues, but if the info you need is not provided or if you are in a big hurry to get your Jeep on the road with working gauges, the above work-arounds might prove useful.
Regards,
Gadget
thanks alot...where did u find this info for the swap? do u know where i can find some info for a 350 swap? its a swap for a new TJ . thanks
you're gonna pay a lot for a custom painless harness... but i say it is worth it
leaking fluids!!! help
yea i know,,, everything i do i wind up paying out the KaZOO but its a jeep. well its my jeep so its worth every penny... hehe
