87SixInlineYJ
Well, I purchased my YJ about 2 weeks ago :shades: and figured ok, this is nice! Lets see what kinda power i can get out of this carburetor system. So, i got a 32/36 weber carb and slapped it in. Loctite the studs, tightened it down, set up my advanced vac line, my filter line, fuel line, float ball vac line, and plugged in the electric choke wire. 8) Im no rookie with engine work, although, in this case, i am the rookie in the carb department. Never touched one before so I made a few idiot mistakes, but quickly stepped backwards and fixed them.
Meanwhile, I go to start her up, and well all i get is it trying and trying to start but no turn over. I pour a little fuel inside the carb, and vroooom, it holds on for about a good ten seconds, and then it turns off.
Then I tweek the idle mixture a lil and get a little bit more of a consistent start like it wants to go, but still nothing consistent.
Curremtly, I am researching all vaccum lines. I have insured that there is no leak at the plates under the carb base.
All linkage appears to be functional and without hinderance.
...this is my saga, if there are any clever minds out there with a little more insite and may have traveled my routes in this vinture please add some knowledge. :?:
I will keep everyone posted!
