2" Spacer lift mods
thejafe
Ok, so I'm thinking of putting a 2" spacer lift on my new TJ when I get it (3 weeks from now I'm hoping)... my questions are:
- If I run 32" tires what other mods will I have to make (regearing etc?)
- How will my TJ behave on the highway with the added height and
larger tires?
- What 2" spacer lift do you recommend?
Thanks everybody... !
www.rubiconexpress.com for the spacer lift with the DoetschTech 3000 shocks. You shouldn't need to do anything else.
Regearing will depend on what transmission (auto or manual) and what your stock axle gear ratio will be. A 4.0L auto with 3.73 gears will be fine, anything else should eventually be regeared but is livable until funds allow.
