Hey guys!
Just took my jeep into the shop for a leaky left rear axle seal which has led to a mountain of repairs...Of course the shoes were soaked, so both had to be repaired, but what worries me most is that once the tech had torn the axle apart, he found that the left rear race was quite loose. With the axle partially disassembled, he showed me how the race spins easily as well as moving in and out - perhaps up to 1/4" (one quarter inch).
He said that this loose race was likely the source of the problems and that if I don't do something about it, I'll just end up trashing my new seal and shoes.
I'm fairly new to lots of this, so I have a bunch of questions...How did the race come loose? By wearing down the inside of the axle housing, I suppose? If I do nothing about the loose race, is it true that I'll be back into the shop quite soon with another leaky seal?
He mentioned something about installing some sort of 'bearing modifier kit' that is supposed to allow me to fit larger bearings into the axle or something...I've never heard of this before and I can't find anything on Google about it... ?
He did mention that he has seen guys pinch up the sides to get it to stay put in the housing, but that he thinks the races come loose in a matter of a few weeks. If I advise him to pinch up the sides of the race (the bearing cup) and use red loctite to secure the race, will this fix the problem?
Is there anything else I should know, or other solutions I should consider?
Thanks so much, guys!
-Rich
-Rich
