i have an o5 unlimited and my hard top was fine last year but this year when i reinstalled it the back window rattles..its driving me crazy is there a way to make it fit tighter when i close the back tail gate. thanks
Did you have a softop on when the hardtop was removed? Check on the tub on both sides of the swing door. If you still have the metal clips that are used to secure your rear softop window attached, remove them. I had the same issue. Don't sell your unlimited. Hopefully this helps you out. Hit me up if you have any questions.
