Standard
Anti-Theft & Locks
# Valet Lockout
Braking & Traction
# Command-TRAC(R) Part-Time 4-Wheel Drive
# Front Power 280-mm X 24-mm Vented Disc and Rear Power 229-mm X 64-mm Solid Drum Brakes
# Automatic Locking Hubs
# Command-TRAC(R) 2-Speed Transfer Case
Electrical
# 600-Cold Cranking Amp Battery
# Battery Saver
# Front Power Outlet
# 117-Amp Alternator
# Audio Pre-Wiring
Engines & Emissions
# 4.0-Liter, Powertech I6, 12-Valve, OHV, SEFI Engine; Front/Longitudinal Mounted With Horsepower Of 190@4600, Torque Of 235@3200, Cast Iron Block and Cast Iron Cylinder Heads
# Extended Service Interval
Entertainment, Communication & Navigation
# AM/FM Radio With 4 Speakers Total; CD Player
# Radio Antenna
Exterior Lighting
# Halogen Headlights
Exterior, Design, Paint & Finish
# Wheel Flares
# Front and Rear Black Bumpers
# Metallic Paint (If Selected)
# Wrangler Badge
# X Badge
# Skid Plates Located On Fuel Tank and Transfer Case
Instrumentation
# Battery Gauge
# Digital Clock
# Oil Gauge
# Audible Warnings For Headlights-On, Key-In-Ignition and Seatbelts Unfastened
# Tachometer
Interior Lighting
# Delayed Courtesy Light
# Engine Compartment Light
# Side Stepwell Courtesy Lights
# Warning Lights Include Low Fuel and Check Engine
Interior, Design, Decor & Floor Covering
# Removable Carpet Located In Passenger Cabin and Cargo Area
Remote Controls & Remote Releases
# Tailgate Release
Safety
# Driver Airbag
# Front Passenger Airbag
# L A T C H
# Fully Padded Safety Rollbar
# Front Seatbelt Height Adjusters
# Front and Rear 3-Point Seatbelts
# Driver Pretensioner With Force Limiter
# Side Guard Door Beams
Seats
# Cloth Seats
# Front Dual High Back Reclining Bucket Seats With Integral Headrests
# Front Dual Easy Entry Seat Device
# Rear Folding and Removable Bench Seat
# Theater Style Rear Seating
Steering
# Power Recirculating Ball Steering
# Tilt Steering Column
Storage
# Covered Lower Console Storage Located On Floor
# 4 Cargo Area Tiedown Loops
# Coinholder
# 4 Cupholders Total
# Front Dual Door Mounted Storage
# Lockable Glovebox
# Front Locking Storage
Sunroof/Moonroof & Removable/Convertible Top
# Manual Soft Top
Suspension
# Live Axle Quadra-Coil(TM) Front Suspension With Leading Arms, Track Bar, Coil Springs and Gas-Charged Shock Absorbers
# Live Axle Quadra-Coil(TM) Rear Suspension With Trailing Arms, Track Bar, Coil Springs and Gas-Charged Shock Absorbers
# Front Stabilizer Bar
# Rear Stabilizer Bar
Towing/Trailering & Payload
# 4450-Lbs. Gross Vehicle Weight Rating
Transmission
# 6-Speed Manual Transmission With Overdrive
Wheels & Tires
# Exterior Rear Mounted Tire Carrier
# Full-Size Spare Tire
# SBRP215/75R15 RBL Goodyear(R) Wrangler RT/S All-Terrain Tires
# Steel Wheels, 15-In. X 7-In.
Windows, Mirrors & Wipers
# Dual Black Manual Folding Exterior Rearview Mirrors
# Front, Side and Rear Tinted Glass
# Front Dual Sunvisors
# Variable Intermittent Windshield Wipers
Doors
# Removable Half Metal Doors With Plastic Windows
Options
4-Speed Automatic Transmission With Overdrive
X Quick Order Package X
Manual Air Conditioning
TRAC-Lok(R) Rear Limited Slip Differential
3.73 Axle Ratio
Brake and Traction Group
Full Metal Doors With Roll-Up Glass Windows
65TH Anniversary Package
Engine Block Heater
Front Carpeted Floor Mats
Locking Fuel Filler Cap
Premium Audio Group
Premium Audio Group
Sirius(R) Satellite Radio
Smokers Group
Sunrider(TM) Manual Soft Top
7 Speakers Total Including Tweeters
Cruise Control
ECCO Tire and Wheel Group
SBRP225/75R15 OWL Wrangler All-Terrain Tires
2 Front and 1 Rear Tow Hooks
Side and Rear Deep Tinted Glass
Hard Top
From
Carprices.com
