Tombredone
I just put on a TFI upgrade, new high pro coil, larger distro cap, new plug wires. I put the wires on in the firing order that it showed. When I try to turn it over, she turns but does not hit to start. I have check the sparkplug and wire connections for fire going to the plugs, and there is a good spark going in, but still not starting. I have the firing order at 1-5-3-6-2-4. I am not sure if this is correct, and yes like a dummy, I did not notate it before I changed out. I have even put the old back on and no hit there either. I have even put a new ECM on it just in case. Yes there is gas going to the carb. What else do I check, and if the firing order is not right, how do I find the correct order for my motor? The numbers on the block are 3218618 and the ones on the manifold are 3227135.4.. Help please,, I can't stand not driving my baby...
thanks
thomas
thanks
thomas
