stock limited slip
seanconnell
hey my 1978 jeep cj-5 has the factory lsd and it doesn't seem to work as well as it should is there a way to adjust it or make it work better thanks
it may need to have new clutch packs installed, but first try adding some LSD (limited slip diffrential :) ) enhancer to the rear gear oil...
one more question my throw out bearing is making a lot of noise i have the 3 speed and i have a spare throw out bearing can i replace it through the side instead of dropping the transmission?
cat pipe
Nope, da transmission has to come off. While you have it out check out the clutcch for wear, replace if necessary. (while you have the transmission out that is!)
