Maint. required light
grooveman
On the way to work my "Maint reqd" lite came on, I assume thats the same as a "check engine" light. Rather than take it to a mechanic Id like to figure out what the prob may be and possibly fix it myself. Anybody know where to get one of those code readers pretty cheap? I have a 92 YJ 2.5L. Thanks[addsig]
1060266
when i need something like a tester and snapon or mac is off the wall i try sears. most of the auto stuff has pretty good warantees too.[addsig]
1060283
on a 92 you should be able to pull the codes with out a scan tool. On my 97 you just turn the key on and off several times and the watch the check engine light flash to figure the code number. If this doesnt work, you should be able to run a jumper wire from two the the contacts in the data link connector to pull the codes. Maybe someone on here can tell you which two contacts. Anyway, you read the code like this..... for example, if the code was 25, you'd have 2 flashes, a short pause, then 5 flashes. if there is a longer pause, it means that you have more then one code.
HTH
Nathan[addsig]
1060284
One more thing. Im not sure if this applies to your jeep, but some vehicles have a timer built in, that after so long of time, set off a light to tell you its time for your emissions system to be inspected. This could be what your light is.
Nathan[addsig]
1060304
I had a problem with my 93 YJ where the check engine light would come on. Turn the key on and off 3 times without starting the jeep then leave it on the third time (I think it's three times). You will see your dash light flash on and off, then pause and start flashing again. Count the flashes and you will get the codes. A short pause is the same number for example 2 flashes, pause, 3 flashes would be 23. A long pause means a new number. You may get more than one code so you may have more than one number. The codes should be in a Haynes auto manual and it'll tell you what the problem is.[addsig]
1060364
I had this same issue with my '91 YJ. This light is on a timer. If I remember correctly, it comes on around 80K or 90K miles. This is simply a reminder to change or service your O2 sensor. The thing with the light is that you can't reset it even after you replace the O2 sensor. There's a box on the firewall that needs to be reset by the dealer to make the light go out. You could remove the box to make the light go out, but I think it's illegal to sell your Jeep if you do that or something. When mine came on, I just put a new O2 sensor on myself, popped the dash panel off, and took out the light bulb behind the Maintainence Req'd light. You might look into having the dealer reset the light. It might be cheap or even free for them to do it, depending on how cool the shop is. I hope this helps.[addsig]
1060366
the counter is like a little mini-odometer below the dash there... its in a tinted clear box with a bunch of white gears in it. i just yanked mine out and threw it in the neighbor's bushes.
-nate
PS... just kidding about the neighbor's bushes...[addsig]
1060371
The box on the fire wall actually can be reset. There is a little hole in the back of it where you can see the white gears and there is a little metal arm that looks like it is jammed in the teeth of the gears this is what sets of the light. Just reach in there with something small and pop it up the light should reset. It is just a timer so idiots will take it to the dealer and get robbed.[addsig]
1060475
It should be just to the right of the gas pedal. Is is a smoke colored see thru box.[addsig]
1061125
nope, not one like described on my firewall :-?
and there's nothing more irritating than paying $$ for someone to do something i should be able to do. maybe they'll do it for free.
sure, a dealer. . .
thought about pulling the light, but i never had a car that had all the lights work at the same time.
some help here, gentleman and ladies?
m[addsig]
1067609
Hi,
The same happened to me, and thanks to the info found here, I managed to reset this little emiss.maint. timer. It was located as you said under the dash and had no problems at all to find this little "switch" and stop that annoying light! Maybe I really should check that O2-sensor too! :) [addsig]
1068167
Some auto parts store will hook there scanner up for free. Autozone has done it for me before. Call around and ask.[addsig]
1068168
If your jeep is throwing a code for a faulty sensor, you can save the big bucks at a shop for diagnostics by following this easy process to figure out what is wrong with your jeep. 91 through 97 (verified, possibly works with newer too) models only.
Start with the ignition off. Within five seconds, switch the key on,
off, on, off, on. (On is not start!)
The "check engine" light will flash. Count the flashes
Each code is a two digit code, so a (for example) 23 would be
FLASH FLASH---FLASH FLASH FLASH
It will never flash more than 9 times, watch for pauses!
55 is end of codes, 33 is normal if you dont have air conditioning.
Please note that some codes are NOT included below, this
is not a complete listing, but it IS very close to complete.
88 Start of test (This only appears on DRBII, it's not blinked out)
11 No ignition reference signal detected during cranking (bad hall
effect)
OR timing belt skipped one or more teeth; or intermittent
loss of either camshaft or crankshaft position sensor
12 Memory Standby power lost (battery cable disconnected)
13* No change in MAP from start to run
14* MAP sensor circuit open or shorted; voltage too low
15 No speed/distance sensor signal
16* Loss of battery voltage detected with engine running
17 Engine stays cold too long (bad thermostat)
21 Oxygen sensor signal out of range, possibly shorted
22* Coolant sensor signal out of range (or disconnected to set timing)
23 Intake air temperature signal out of range
24* Throttle position circuit out of range
25 Automatic Idle Speed (AIS) motor driver circuit shorted
or target idle not reached, vacuum leak found
26 Peak injector circuit voltage has not been reached
27 Logic module fuel circuit internal problem
OR
27 TBI injector does not respond properly to control signal
31 Evaporator Purge solenoid circuit open or shorted OR
Evaparator solenoid circuit
32 EGR system failure OR
Power loss lamp open or shorted
33 Air conditioning clutch relay circuit open or shorted
34 Speed control vacuum or vent solenoid circuits open or shorted
35 Cooling fan relay circuit open or shorted
36 Wastegate control circuit open or shorted
37 Shift indicator light failure, 5-speed (blown bulb) OR
Park/neutral switch failure
OR
37 Torque converter unlock circuit open or shorted, A-413 4-speed auto
41* Alternator field control circuit open or shorted
42 Automatic shutdown relay circuit open or shorted
42 Fuel pump relay control circuit
42 Fuel level unit - no change over miles
OR
42 Z1 voltage missing when autoshutdown circuit energized (whatever
that means)
43 Peak primary coil current not achieved with max dwell time
OR
43 Cylinder misfire
43 Problem in power module to logic module interface
44 No FJ2 voltage present at logic board
OR
44 Logic module self-diagnostics indicate problem
OR
44 Battery temperature out of range (see Note #1!)
45 Turbo boost limit exceeded (engine was shut down by logic module)
46* Battery voltage too high during charging or charging system
voltage too low
47 Battery voltage too low and alternator output too low
51 Oxygen sensor stuck at lean position
OR
51 Internal logic module fault ('84 turbo only)
52 Oxygen sensor stuck at rich position
OR
52 Internal logic module fault ('84 turbo only)
53 Logic module internal problem
54 No sync pickup signal during engine rotation (turbo only)
OR
54 Internal logic module fault ('84 turbo only)
55 End of codes
61 "baro" sensor open or shorted
62 EMR mileage cannot be stored in EEPROM
62 PCM failure SRI mile not stored
63 Controller cannot write to EEPROM
64 Catalytic converter efficiency failure
65 Power steering switch failure
Copied from BC4x4.com
1068817
Thanks for all the input. I changed the O2 sensor. I could never locate that little timer box so I just pulled the bulb.[addsig]
